Author Topic: Free Plans: Staircase drawers and Stair box  (Read 38407 times)
Deana
  • Guest
« on: March 04, 2007, 07:42:27 AM »
STAIRCASE DRAWERS:
In-step drawers turn wasted space into a storage place
http://www.canadianhomeworkshop.com/weekend/risers.shtml
STAIR BOX:
This clever step-hugging box collects all that stuff for the next trip up or down the stairs
http://www.canadianhomeworkshop.com/proj/twostep.shtml
  • Guest
Re: Free Plans: Staircase drawers and Stair box
« Reply #1 on: March 04, 2007, 08:09:16 AM »
Thanks for that lead Deana  :D
The staircase drawers is a killer idea for extra storage in a small house.
« Last Edit: March 04, 2007, 08:10:00 AM by jraabe »
peg_688
  • Guest
« Reply #2 on: March 04, 2007, 08:23:14 AM »
Neat idea , but where's the stair horse's ?? Code sez 12" OC with a 2 by tread.
 Those treads look to be 5/4" thick and the spacing between the horse's carriages is way to far even if you don't have to meet code , those treads would bow under the weight of a 75 LBS child.
 So,  neat idea but not a very "good " idea ::)
[highlight] IT could be a killer idea [/highlight], if say some one down stairs opened a draw and some one upstrairs decided to use the stairs , say carring a basket of laundry down the stairs as well!!! Good way to "get rid of" a spouse / unwanted roommate , etc ;D
  Sorry to be so negative but ......
  • Guest
« Reply #3 on: March 04, 2007, 09:50:30 AM »
Interesting point, PEG.  Does that mean 3 stringers (horses) under a 3 foot wide stair with 6" cantilever at each end?  Then it seems that 2x would be overkill but if it's code I guess it's code.
I guess it would be better in that case to make storage accessible from under the stairs then.
  • Guest
« Reply #4 on: March 04, 2007, 01:49:57 PM »
Point taken PEG - You are right, those are TWO BIG questions.
What if instead of sliding drawers you did two hinged doors between the center 2x12 horse? Put the hinges at the top so that gravity closes the hatches. It wouldn't be quite as accessible as a drawer but safer, sturdier and easier to build.
Block in a 1x on top of the tread all the way back to the edge of the horse. This would be the stop for the door (maybe with a magnetic latch). Do a piano hinge or leather hinge at the top.
The question might be "would this be worth the trouble"?
« Last Edit: March 04, 2007, 02:00:09 PM by jraabe »
  • Guest
« Reply #5 on: March 04, 2007, 06:43:33 PM »
PEG,would 5/4 work if it were nice clear oak or hickory?
No particular plans to do it, just wondering.
(I'm with the people who think that if you must have stairs, they should be as uncluttered--and unclutterable--as possible.  Japanese farmhouses that I've seen pictures of might have had something like that, or the steps lifting up for storage--or a series of drawers and cubbyholes and coming out to the side, what we'd call a tansu.  But no railings.)
  • Guest
« Reply #6 on: March 05, 2007, 07:12:00 PM »
Having the stair treads lift sounds like a good compromise over just the drawers.
  • Guest
« Reply #7 on: March 06, 2007, 07:12:26 AM »
If you were going downstairs, at least you would pretty automatically kick them down!
Offline Linda Vista Farm
  • Apprentice
« Reply #8 on: March 02, 2008, 05:50:45 AM »
great place to hide valuables. Thanks for the post.
Johnny
Offline considerations
  • Joyce, Washington, (sort of)
Offline StinkerBell
  • CountryPlans member
« Reply #10 on: April 18, 2008, 08:34:39 AM »
I do like the idea you posted considerations, but they steps look very steep.
Offline John Raabe
  • Whidbey Island, WA
    • CountryPlans - About Us
« Reply #11 on: April 20, 2008, 03:38:35 PM »
Yes, those risers are taller than current codes allow for a full stair (7.75" for an IRC stair), but could be fine for a small loft.
The design concept would work just as well for shallower stairs - with a shallower drawer, of course.
There is the small question of what holds up the stairs when you cut through the 2x12 stair stringers that are normally on either side of the stair supporting the treads and risers.
« Reply #12 on: April 21, 2008, 07:28:20 AM »
As far as the side drawers in the stairs goes.  I'm so new to interior finish work that I'm still just surfing the net and hanging on to things that look like cool ideas, with no knowledge as to the practical considerations.   That is what I like about this forum, I have confidence that I can end up with practical and cost effective solutions, because you all are out there to discuss and share ideas.  I don't think I could do this by myself otherwise.
Offline John Raabe
« Reply #13 on: April 21, 2008, 07:52:40 AM »
I want to thank you for the contribution Considerations.  :D
Keep them coming! There are lots of helpful "wood butchers" here who will help figure out how to make these things work. We even have Glenn who knows how to make things out of metal! :o
Offline glenn kangiser
  • The Troglodyte
    • Underground Cabin
« Reply #14 on: April 21, 2008, 09:33:14 AM »
...and junk. [crz]
The way I see the above stairs working with the drawers is if they carried a plywood piece - maybe 1" thick under the tread behind the top drawer framing -- and continue it all the way to the back for each step, where it could be supported by the back wall.
The stairs with drawers, would still work even if not that steep.
