The 1.5 Story Cottage
- 875 square feet (20’ x 30’)
- Full-sized loft
- 1-2 bedrooms (loft can be 2nd bdrm)
- 1 bathroom
- 3 Foundation plans included
- Porch plans included
- Electrical & plumbing plans included
- Materials List included
- Editable CAD file available
PDF plans are complete ready-to-print drawings for permits and building. CAD plans add the editable drawing files, so you or a designer can make changes in CAD software. Paper plans are printed sets shipped to you.
Already own an older paper set of these plans? Adding the current PDF to your set is $75, and adding CAD + PDF is $350. Booklet and materials list come with it. Write to questions@countryplans.com with your name and the plan.
Purchase the 1.5 Story Cottage Plans
Order Plansfrom $325 · PDF, Paper or CADPDF and CAD arrive by email, usually within hours. Paper plans are 5 printed sets by USPS.
This simple to build classic cottage has 875 sq. ft. of living area counting the full sized loft (275 sq. ft. of floor area over 6' of headroom) and the 600 sq. ft. 20'x 30' main floor (you have options about the size of the loft). Since all floors and roof bear on the outside walls, the interior of the floor plan can be redesigned to your liking. The framing system is simple and is designed for small crew construction so it can be built by owner-builders. This is one of our most popular plans. The 6-page materials list includes all materials for the post & pier foundation, all framing, hardware, insulation, windows and doors, drywall, electrical, plumbing and interior trim. This list is in Word DOC format (and PDF) so it can be modified and updated as the project progresses.
The loft floor plan in the plan set draws the loft running the full length of the building, with 275 sq. ft. of floor area over 6' of headroom. The floor plan image at the top of this page shows the smaller-loft version of the same plan, with the loft above the bath and main floor bedroom. You can build it either way from these drawings: the Great Room can have an open cathedral ceiling with rafter ties, or you can continue the 2x12 loft floor joists making the usable loft area the full length of the building. There are three different foundation types in the plans: concrete crawlspace, slab on grade (2 versions for different climates) and a post and pier foundation. You choose the one you want to build. If you wish, this plan can be extended in length as the structural frames can be duplicated on 2' increments. It can be built with a full or partial loft.
The plan set includes 11 sheets of drawings, covering everything needed to apply for most building permits. Here is what is on them:
- 3 foundation plan sheets - one each for post & pier, slab or crawlspace foundations (you will submit one of these)
- Main floor and porch plan with electrical layouts and door and window call-outs. The same sheet carries the cross section drawing showing framing and insulation levels, stairway construction and a header chart for wall openings, plus diagrams for locally made roof trusses (for easy engineering).
- Loft floor plan with electrical and a loft framing plan with two ways of constructing the floor
- Loft roof details and cross section of site built truss and wall to truss connections
- Loft floor to wall details for supporting the joists or exposed beam ceiling
- Porch and deck plans for both a hip end porch (shown above) and a wrap around porch or deck. This can be extended as desired.
- Includes deck and roof framing details & railing details
- Four building elevations showing roofing, roof trim details, siding suggestions and porch and roof slopes. Includes total Bldg. height (about 22 feet)
- Trim corner details, window & door trim details (inside and outside), corner trim detail, window hood detail, and tips on extra money saving ideas for finishes
- Standard window and door sheet for cutting out and replacing doors and windows in the existing plans (allows cut & paste drafting for simple changes)
- Plan notes include suggestions for heating and cooling and two different locations for the hot water tank (electric or gas)
Here is a view looking at the steep cottage staircase and a beam and deck ceiling over the Great Room. There is also a stair layout for a full sized "U" shaped stair if needed. This will take more floor area but often works better with a full length loft. With the steep stair a pantry is tucked under the stairway.
Every set ships with a free 14-page booklet:
- Notes on how to customize your plans
- An Open Beam Ceiling guide
- A How to Read Plans guide with diagrams and a glossary of standard building terms
- A checklist and tips for going to the building department
- Info on foundations and soil types
- Platform Framing info
- Earthquake and Wind Bracing info
- Alternative cottage stair plans for use with the loft (or basement)
The Materials List
Every set comes with a materials list: a six-page take-off of the shell, as an editable Word file and a PDF. It was put together by a professional take-off service. The pages run from the sub-floor and wall framing up through roofing, siding, doors, windows, insulation, drywall, rough hardware, plumbing and electrical, with a blank price column for you to fill in.
Take it to a lumber yard and get a quote before you commit. The list is for comparing suppliers, not for ordering. A note on every page says what it leaves out: foundation concrete, rebar, wire mesh, visqueen, cabinets, complete plumbing and electrical materials, HVAC, finish flooring, paint and appliances. Trusses come from a local truss manufacturer. You can edit the Word file for your own material choices; save it under a new name to keep the original.
The list used to be a paid extra. It comes with the plans now.
Dimensions and loads
The numbers people ask us before they buy.
- Footprint
- 20' x 30'. 600 sf on the ground floor, 875 sf with the loft.
- Wall height
- 10' balloon-framed 2x6 side walls. Several builders use 12' studs for more headroom in the full-length loft.
- Loft or second floor
- The loft floor sits 2' below the top of the 10' wall: about a 2' kneewall as drawn, about 4' with 12' studs.
- Ceiling and headroom
- 8' on the main floor, 7'-6" at the loft.
- Roof pitch
- 8/12 as drawn.
- Design snow load
- Not certified for one site. Your truss company engineers the trusses for your local loads. John Raabe, who drew these plans, said his charts made the open-beam 2x12 option good for 55 psf.
- Height to peak
- About 21'-4" finished floor to peak, 22'-6" ground to peak on a crawlspace, 21'-6" subfloor to ridge.
Dimensions come from the plan sheets. None of these plans is engineered for one site: sheet 4 shows a site-built truss, a truss company can design trusses to your local snow and wind loads instead, and your building department has the last word. Ask us about anything not here at questions@countryplans.com.
Related discussions on the forum
Here are photographs and the story of a rustic owner-built home in remote Prince of Wales island in Southeast Alaska:
“I picked a plan from CountryPlans for the design and affordability. Like most of us everything is always a stretch financially and this was no different! I wanted a plan that used common materials and dimensions to keep costs down and this was it. One step at a time and my cabin came to life. Finding a lot with a low initial cost and easy financing was first and the University of Alaska made that happen. Each step was the total of what I had available to put into the cabin. I did not buy the lot and imagine the cost would be X dollars. There would have been no cabin if I imagined the total cost of construction. After purchasing the lot, my only focus was getting building site cleared. The focus was then the foundation and so on. I had no idea how long the cabin would take. Each time I would begin collecting what I needed from a variety of places. I became a fan of Craigslist! I would watch daily and collect things such as a $50.00 wood stove and the slate remnants to put behind it. With no timelines, costs go way down. Everything was exciting and became part of my dream as I imagined it being used.
As construction began, the dreams developed into memories. We went from camping on a gravel pad to a cabin over 5 years. We froze inside with a roof over our heads but no windows or heat and tar paper on the exterior walls. But in the morning we woke up to our dreams again. The steaming cup of coffee quickly made us forget that we were "roughing it." Windows and insulation WOW now we are living the high life! Pasta and Ragu cooked over a camp stove teetering on a scrap piece of plywood made into a makeshift kitchen counter and we may as well been at the Ritz! I really can't express how exciting each step was for myself, my family and friends. I have never regretted starting my Cabin. If I were 5 years into it and had just a one room 12x16 with a simple plywood loft and an unfinished interior, I would still be as excited as I am today.
So what is the point of all of this babbling? In the words of the Nike marketing department, 'just do it!' I was as excited as a kid at Christmas with just a set of plans and a dream. Now I have a cabin, a heart full of memories and family and friends with a place they can use for life. It was one step at a time. Make no mistake. My friends put in countless hours of blood and sweat into this cabin. For that I will always be grateful, and I hope they have fond memories as well. My advice to others would be to just get started and look to the great help of the Country Plans members for assistance.
Thanks, John, for creating CountryPlans. If I had not found your site with cabins for all of us, I very well might still be dreaming.
Mike Cowan”
